hi sony i broken my sony experia z digitizer and my fon is out of warranty i make it repair locally after screen replacement it is showing "unfortunatly camera has been stopped" now please tell me what to do. plz
You could try clearing cache and data for the camera app or if it was me then I'd try the below and if that fails then it could be that the ribbon cable/connector has been damaged or simply not connected correctly or at all
Performing a system repair using PC Companion - This will factory reset your phone and erase all data so best to backup before you begin
