Camera issue
Arsh876
Camera issue
when i take photos using flash.. light is filled up at the edge of every photo. it is a software or hardware problem?? has anyone experienced it??
3 REPLIES 3
Shadow93
Yes it happens with me too especially at night (very dark) when you take a photo using the flash the right side of the photo become white,the cause is not from the Camera the cause is from the glassy back of the phone ! and because the flash is pretty close to the camera so when u try to take a photo to a far object in low light you get this issue the flash light is pretty strong so it spread throw the class and reach the right side of the camera , you can check it out by your self but watch out don't lock directly to the flash lol like I did ,but if you take a photo for a close object this issue wont occur cause the camera will be busy with focusing on the close object unlike taking far photo !
what I hope is that sony can make some few change in the camera software to avoid this problem ! Thinking_Face
Arsh876
tnx.. but there is no solution for this?? this is awful from sony..
Shadow93
Anytime friend, and I don't know really I'm like you I was hoping the new 4.4.2 fixs this issue but sadly nothing changed 😕
even if you used other modes or other apps they shows the same issue,be sure that the camera is not the cause ,its almost like you are taking a photo for a projector but a tiny one lol , anyway I'm waiting for the new 4.4.3 let's see if anything will change.
and yes its bad they should think about this problem before everything, at lest they should cover the surrounding of the flash light so the light wont spread throw the glass to the camera Slightly_frowning_Face
