Suddenly camera app gives 90 degrees twisted view and takes pictures also twisted, and wrong sizes/deformed, height is width and width is height.
If I use front camera its all fine.
If I use Quick Launch its all fine.
If I use diagnostic app everything works OK, normal view and pictures.
Reset using PC Companion does not work.
Can anyone help me?
If a software repair has not fixed the issue then I can really only advise you to get the phone through to an authorised repair agent, please contact your local Xperia Care team for assistance with this.
Did you also reset to factory settings?
