Camera hardware button not responding at all...
coolprateek7
After ICS update my hardware camera button is never responding.... Did they intentionally disabled hardware button and give
The software slide Button in lock screen?
4 REPLIES 4
profile.country.PH.title
MarlonUk1
have you tried to check the camera settings, to see if the capture mode is set to touch only?
try to check using service test, dial *#*#7378423#*#* under service test keyboard and switch, see if it is detected
Sam
Legend
Legend
You may also need to run a repair to reload the firmware.
coolprateek7
Thank you nolramlb I did as you said and run those tests... Its good. Detects both autofocus as well as camera.... Hardware seems good...
coolprateek7
all right.. I'll do it....
