camera flash n torch
rickyXMSA
my flash just stopped working
Tags (1)
5 REPLIES 5
profile.country.RO.title
_alexdon_
Settings-apps-all-camera,force stop and clear data.Restart.
alexdon
Phy
Legend
Legend
does it work while on safe mode? has your phone been exposed to water?
dynames14
My flash suddenly stopped working, i tried with the options left here but whatever does not work
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Don't forget to backup
PC Companion (PCC)
Bridge (for Mac)
