camera flash light issue
RawatMahender
I have purchased Xperia Z1 in Feburary 2014 and having flash light issue in Photos. If i click without flash then image comes fine but if i click with flash then at the bottom of Image(flash side) there is a extra light comes which is flash light. And that flash look more ugly if i click in low light enviroment. I used all of settings (Auto, Daylight, Night Scene). In all setting if i click in low light there is extra flash comes in Image.
Note : My Xperia is full update using sony update.
4 REPLIES 4
Alexander1
I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
antenorhs
Do you use some kind of case, cover, or cover at the cellphone's back?
If you use, try to take pictres without it.
RawatMahender
Yes i am using back cover as well and for me as well  first impression was issue of back cover but i took many pic without back cover but issue same. Flash light look more visible in pic when took in low light.
Below pic i click with flash light and you can see the impression of flash light in Pic at the bottom
and Below pic i click without flash.
and one more thing when i update my Xperia Z1 to 4.4 Kitkat my mobile apps volume goes down automatically sometime even for incoming call ringtone as well.
Saintgein
I have the same kind of flash bleeding in my pics. But i noticed that if i start working the iso levels, this gets alot better! Not sure if this is a software thing or hardware fault. I can post example pics if you guys want?
