Open Settings then Apps then swipe to All then locate and open Camera then tap on Clear cache and Clear data then reboot and test or open Settings then Apps then tap the 3 dots then Reset app preferences then reboot and test however in doing the latter your ringtone etc will default back to stock
The only other option is a system repair as below
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
@Wirepath Before you try the repair,did you check accesibility under settings? Perhaps there are some magnification gestures set up.
