Hi, I would like to know if it is possible, and how, to have a quick camera button on the pattern lock screen. without unlocking the phone.
Thank you in Advance
When using pattern lock it's not possible to have a shortcut to the camera on the lock screen.
But... I use pattern lock and I have a camera shortcut on my lockscreen. You just swipe right to left.
No, pattern lock is not the same as for swipe to the left or right. This is pattern lock:
Yes. I know what pattern lock screen is. I use the pattern lock screen. And with the 4.2.2 update, you can swipe from right to left when using the pattern lock screen to launch the camera.
/thread.
You are totally correct. I just assumed that Wismy didn't have 4.2.2 as he couldn't have camera & pattern. My bad :smileyhappy:.
Well we're both right then!
* If the OP has not updated - he should update to get this feature.
* If the OP has updated - all he needs to do is enable the pattern lock screen and swipe right to left.
* If the OP has no update available - this feature is not available for the pattern lock screen.
So OP, have you updated or not...?!?
