Hi
My Z3 Compact's camera is acting up. It does not want to rotate from portrait to landscape, it only operates in landscape.
I read some of the other solutions and tried it but all that is left is rapair device and i am hesitant due to the fact that i will lose all my info om my phone.
the sound problem that i am having is that the device does not play the music proberly through the aux cable.
please can you assist with this
Hi @Annali
Please, try boot your device into safe mode to check if this issue persists:
If everything works ok in this mode, a third party app is generating this issue, but if the problem was not solved, I suggest you to first run a backup of the device information to prevent losing information like this:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
Try performing a system repair using PC Companion:
http://support.sonymobile.com/gb/tools/pc-companion/
This will factory reset your phone and erase all data. You might need tocharge your device for about 1-2 hours before so the device has at least 80% battery. Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device). Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP.
In PC Companion you press start on Support Zone -> Start on Update the phone/tablet software -> Repair phone/tablet (the blue
clickable link in the message) -> Follow these steps without having your device connected to the PC.
If it's not possible to perform this software repair, you could check the following FAQ topic regarding USB connection problems:
/t5/FAQ/USB-connection-problems/m-p/348074
I'm at disposal for any question.
Best Regards,
Hi
i started my phone in save mode and the camera had the same issue.
I have made backups of my phone by i am very nervous and not really prepared to whipe all the info from my phone. this is not a solution, it will only create more problems for me.
Did you try to clear Camera cache?
- Go to Settings -> Apps -> All -> Camera -> Clear data and restart your phone.
Hi
i have tried it before and now again and it is not working.
