Calling via Car
n0nsense
Calling via Car
Hello. I've got problem with calling(IN\OUT) via car bluetooth. (Camry XV50).
When the call is finished, my phone is not getting blocked and randomly activating everything on the screen(calls,camera,GEO loc., etc).
5 REPLIES 5
Didrik
Enthusiast
Hi @n0nsense,
Do you mean that your display is lit when you get a phonecall?
Does the same thing happen when connected to another Bluetooth accessory that can handle calls? Have you tried this in safe mode?
n0nsense
"Do you mean that your display is lit when you get a phonecall" - Yes."
"Does the same thing happen when connected to another Bluetooth accessory that can handle calls? Have you tried this insafe mode# "  - I will try, thanks.
Didrik
Enthusiast
@n0nsense,
Please keep me posted if you can recreate this while in safe mode or not.
n0nsense
So, i've tried ro recreate it in safe mode (in same car, not other BT-devices) - there is no problem, screen was locked after phonecall.
3rd party apps can be reason in normal mode? Like a Skype or Call Recorder?
Didrik
Enthusiast
If it works in safe mode then this is caused by a third party app in your phone. Although it's hard to say exactly which one there are a few things you can try.
Start by updating all your apps. Should this not help then continue by uninstalling the latest apps you installed or the ones that can manage connected devices or handle calls. If you still experience this after that then you will most likely have to uninstall all your apps and reinstall them one by one to find the one causing this.
