My mini is on a call and will not disconnect.
I can also not turn the phone off, is there a way I can reset the phone?
If you want to reset your phone then go to
Settings > SD Card USB Mass Storage > Factory Data Reset.
I think the problem with you is lack of internal memory. Have you installed a lot of programs??
I have not downloaded any programs apart from an update last week.
I have done reset and just waiting for restart!
just restarted and tried to make a call, that worked fine but still would not hang up.
I can't figure out your exact problem. Are you saying that the disconnection button on the bottom right (appears when you are on a call) does not work?
