Call log empty
robmif76
Call log empty
The call log on the Compact isn't populating. I've tried doing hide and then show call log, as well as adding and removing filters but nothing works it just stays blank. Interestingely, I've added a call log widget to one of the screens and this populates fine.
Any ideas?
thanks
Rob
24 REPLIES 24
maax
Z1 compact upgrade kitkat - tap to wake not present, why??
maax
xperia Z1 compact upgrade KITKAT - call log empty as before upgrade!
tap to wake was never promised, same as 4K recording, as for your call logs, I still have all my call logs
maax
call logs empty is a problem already known and opened many topics, already 'with Android 4.3
search "call empty logs" in forum..
it's true that was not promise, I would be expecting me..  in Z2 is present..
thx
You should not create new threads if you are aware of ongoing threads on the same or similar topics
Arpinacio
Hi there.
I was facing the same problem and found some kind of a solution.
I've installed a call log from Google Play (Call Log Monitor, one with a red icon) selected all the log (with the check boxes) and delete the log. On the Phone log it appears a message saying "Call log empty", tried to make a call and the call appeared on the log.
Problem solved, with a little effort.
I think that the problem is with the recover app from Sony, so... DON'T use it Grinning_Face
Hope this post can help you all.
HEMA
worked for me
xperia z1 Slightly_smiling_Face
thank u
FAT_C
Thanks Arpinacio, it works!
Gowest
Thanks Arpinacio for the All log app suggestion, but my log still did not populate - as I make a lot of calls this is a very frustrating software fault.
Rickard
Try clearing the call log using this app and see if that helps: https://play.google.com/store/apps/details?id=mobi.infolife.eraser
