Call goes to speaker automatically
DiegoQueiroz
I know that this issue was reported before, but I need to inform that it is not solved (or we are dealing with a regression bug):
I use Xperia Z2 (D6543) and sometimes when I answer a call, it goes straight to loudspeaker.
This problem does not happens often (so it is a pain to reproduce it), but is seems to happen when I receive a call while the phone is in standby for a long period (about 4 hours).
When that happens, the loudspeaker button does not display as selected, so to disable it I need to double hit the button to change the audio output (the first hit re-enables it, and the second disables it).
Currently, I am using Android 5.0.2 Lollipop, and Google Chrome 42.0.2311.111.
I did not try to disable Chrome yet, but I am afraid this is not an option for me. Instead of this, I would be glad if this issue became addressed by Sony developers again.
4 REPLIES 4
Clear the app data on
settings > apps > all > phone, smartconnect, chrome > restart the phone > check again.
DiegoQueiroz
@uliwoolyI'll try your suggestion, but it will take some time to confirm if it works or not. But even if it works, I still think the problem should be addressed by Sony developers.
I think it's an app acting up but keep us updated, this is what I would do
1. repair the phone with PCC > do NOT install any aditional app for a day or two and see if you encounter the same problem
or
2. boot on safe mode and use it for a day or so and see if you encounter the same issue.
@DiegoQueiroz
