call ended
call ended
I am facing a problem at making calls. it is showing call ended. plz help.
2 REPLIES 2
Nabeel
See if software repair helps...
Markus1
Leader
Does this always happen? If not, when does it occur (e.g. with certain numbers, or when at a certain location etc.)?
Can you please borrow a SIM card from someone, put it in your phone and see if the same problem occurs?
What phone model are you using?
