After updating my xperia Arc-S to ICS 4.0.3 the calendar widget didn't show the all-day events from google calendar.
in that time according to : http://code.google.com/p/android/issues/detail?id=22365
"We fixed an usability issue associated with all-day events in the widget. They will be in the widgets again in an upcoming update."
and after 4.0.4
"For those of you with 4.0.4, you should see all-day events (in the next 7 days) in the widget. If not, please let me know."
but after updateing to 4.0.4 the problem still there and the widget only shows "No upcoming calendar events"
and when I've asked them about this the answer was :
"Sorry. Please contact Sony. Looks like they customized the calendar app and didn't pick up my changes."
What should I do now ?!
I will pass this on to developers to have them check this.
Dear Johan,
Thanks for your prompt reply. I was beginning to worry why nobody answers my question.I'm impatiently looking forward to further information from you whether: should I wait for the next Android update 4.0.5 or a firmware update for Xperia Arc S will be provided or Calender Widget will be updated? Thank you for your time.
Best regards,
yes please !! fix this !! tks sony !! u guys rock !!!!
Dear Johan,
Today I faced a more complicated problem which is "Contacts' birthdays and events" doesn't appear in calendar app!!!
Best Regards
As you can see below, the all day long event does not show anything on ICS.
I hope this picture will help you to reproduce the problem. Thanks. My phone: LWW ICS 4.0.4
Message was edited by: darf
Same problem on my Xperia Mini Pro with ICS 4.0.4 !
I hope Sony will correct all of the important bug of ICS
Please fix this. The all day events are visible in the calender widgets of other OEMs. So making them visible wouldn't be a problem to anyone now that even the widget is scrollable. Please fix this fast Sony!
I haven't seen an update come out which has fixed this, if the problem has not been identified then I'd like to point out that it was originally a base android bug which was fixed in trunk, presumably after you took your development copy of the code.
I can't remember the exact correction but it should be easy enough to find again for someone in development.
If this has already been corrected and my phone is just not up to date then disregard this comment.
