Since my first setup, nor the original calendar widget nor the google calendar widget is refreshing.
In the calendar is all ok, but after inicial task listing, old task erase from the list, but doesnt show new ones, only have one event and suspect after the event pass it will not list anything.
Removed widgets several times and when adding again, still same problem.
The likely issue is that you will be running WAP settings instead of Internet settings. Please check with your network provider regarding this issue.
