Calendar on lock screen
AlphaO
Question, when the calendar widget is on the lock screen (Very useful) it only displayes the date and the top portion, so you cant really see any items. Is there a way to change it to say make it larger? or change the way the calendar looks?
Maybe a custom calendar app? I'm liking having the calendar on the lock screen, i see my appointments with the push of the power button, but right now it's a two step process: 1) push power, 2) swipe down to see more of the calendar.
Thanks.
2 REPLIES 2
Jake-SonyXperia
Hi AlphaO,
Unfortunately there is nothing within the handset that allows you to change this function. I can only really checking through the Play Store, there is very likely an application that can be downloaded to help with this.
I apologise for any inconvenience this may cause.
AlphaO
Thank you Jake.
I downloaded a different calendar app and it works better (the Google calendar works better than the Sony one as a Widget)
But yes, if there was a way to make the Lock screen Widget realestate bigger, (as an option) that would be a great update.
