c902 charging problem
My son's c902 keeps showing the message 'serious error, stop charging and contact sony ericsson customer care', or something v similar.  After researching online, I purchased a new battery, believing it would cure the problem, but no, the message is still appearing.  Any ideas?
Dr_Chris
Does this happen when you charge the phone via the USB cable? If not, then it sounds like a faulty charger.
If it gives you the same message when charging via USB or with a different charger, such as a car charger,
wipe any dirt off the phone's fast-port connector pins and try again.
If this doesn't work, check/clean the battery terminals and contacts inside the phone.
Hope this helps.
