arrived in the post today. lovely piece of kit - - if only the camera worked. I have tested with the phone, and its not working. if you tap the icon, there is a click, followed by the message "Unfortunately camera has stopped". Can anyone help me please?
Have you tried settings-apps-all-camera,force stop and clear data?
@Phy wrote:
If Alexdon's suggestion doesn't work, you could repair your phone with Sony PC Companion
http://support.sonymobile.com/gb/tools/pc-companion/
Performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
I tried all the advice given. Then contacted the retailer. The phone was returned to him, and a replacement issued. Thank you.
