buletooth problem in sk17i
achilles9546
Hi
I am facing an issue with my Bluetooth. Not able to recieve files from othe cellphones.I am able send files, but not able to recive any.Error sending failed on other device. Tried with 6 different handsets. This is happining after the updated the phone to 2.3.4
8 REPLIES 8
gwhispererz
Hi, a stupid question .... did you mark Discoverable for Bluetooth settings?
slimshaddy
Hero
first check what gwhisperez suggested,,
if that was the problem and you solved it then its good if not..
then delete all your paired devices in your phone..
go to settings > wireless and networks > bluetooth settings
and you will see all the paired devices..
so just delete them all..
and then try,,
achilles9546
I dnt know who made this guy a moderator..dumest answer I might have got. Before posting on this forum I tried everthing that I could possible do. ''such as'' make it discoverable, then unpair every everything,after that I tried to turn off the Bluetooth and switch it on '' no change'' and also turned off the phone removing battey sim carthend for 10min then. '' no change''. I actually reset the phone not able to recive files.....now tell me is there any thing left .what should I do more.? BUT HONESTLY I APPRECIATE THAT SOME ONE DID ANSWER MY QUESTION.THANKS VERY MUCH FOR THAT.
Sam
Legend
Legend
Please refrain from insulting people on this forum, gwhispererz' question is relevant as you had not stated you performed this step in your first post so we just try to rule out the obvious. However given the nature of the problem and that it occurred after an update I would advise running a repair via PC Companion to reload the firmware as there may have been an issue in applying the firmware when you updated previously.
achilles9546
Hi
Thanks for reply. I ll try it.
slimshaddy
Hero
well obviously he was just starting from a basic solution possible..
if you need help you should appreciate it and not just go on insulting people..
i have made a topic in dell support for my laptop..and no one has replied to that..
it has been 5 days since i posted..
so you should be thankful we are replying..
gwhispererz
Obvious is often seen as dumbest .... However, dumbest is not always obvious.
Anyway, keep us updated. Slightly_smiling_Face
slimshaddy
Hero
after reaidng this i'm sure he will take his words back Smiling_Face_with_open_mouth_&_closed_Eyes
