Bug report: phone dies on incoming or outgoing calls
bozho
Hello,
My Sony Xperia Z3 Compact, with the latest updates, is dying _sometimes_, whenever I receive a call or dial someone. It is not always reproducible, but I managed to reproduce it while it was attached to LogCat, so here's the exception:
09-13 18:49:01.529: E/ACDB-LOADER(316): Error: ACDB AudProc vol returned = -19
09-13 18:49:01.814: E/ContactPhotoManager(31219): No contact photo service in context: com.android.incallui.InCallApp@1a85823f
09-13 18:49:01.832: E/AudioMixer(316): AudioMixer::getTrackName out of available tracks
09-13 18:49:01.832: E/AudioFlinger(316): no more track names available
09-13 18:49:01.832: E/AudioFlinger(316): createTrack_l() initCheck failed -12; no control block?
09-13 18:49:01.835: E/AudioTrack(857): AudioFlinger could not create track, status: -12
09-13 18:49:01.836: E/ToneGenerator(857): AudioTrack->initCheck failed
09-13 18:49:01.836: E/ToneGenerator(857): ToneGenerator init failed
09-13 18:49:01.848: E/AndroidRuntime(857): *** FATAL EXCEPTION IN SYSTEM PROCESS: main
09-13 18:49:01.848: E/AndroidRuntime(857): java.lang.RuntimeException: Error receiving broadcast Intent { act=android.intent.action.PHONE_STATE flg=0x10 (has extras) } in com.android.server.notification.NotificationManagerService$3@1384d6f1
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:882)
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.os.Handler.handleCallback(Handler.java:739)
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.os.Handler.dispatchMessage(Handler.java:95)
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.os.Looper.loop(Looper.java:211)
09-13 18:49:01.848: E/AndroidRuntime(857):     at com.android.server.SystemServer.run(SystemServer.java:295)
09-13 18:49:01.848: E/AndroidRuntime(857):     at com.android.server.SystemServer.main(SystemServer.java:183)
09-13 18:49:01.848: E/AndroidRuntime(857):     at java.lang.reflect.Method.invoke(Native Method)
09-13 18:49:01.848: E/AndroidRuntime(857):     at java.lang.reflect.Method.invoke(Method.java:372)
09-13 18:49:01.848: E/AndroidRuntime(857):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1020)
09-13 18:49:01.848: E/AndroidRuntime(857):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:815)
09-13 18:49:01.848: E/AndroidRuntime(857): Caused by: java.lang.RuntimeException: Init failed
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.media.ToneGenerator.native_setup(Native Method)
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.media.ToneGenerator.<init>(ToneGenerator.java:763)
09-13 18:49:01.848: E/AndroidRuntime(857):     at com.android.server.notification.NotificationManagerService$3.onReceive(NotificationManagerService.java:794)
09-13 18:49:01.848: E/AndroidRuntime(857):     at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:872)
09-13 18:49:01.848: E/AndroidRuntime(857):     ... 9 more
09-13 18:49:02.542: E/Holla(9878): HollaChannelProxy.java:258 (main)| Unable to resolve contact alias
09-13 18:49:02.562: E/MDM(2625): [242] b.run: Couldn't connect to Google API client: ConnectionResult{statusCode=API_UNAVAILABLE, resolution=null}
09-13 18:49:02.578: E/Holla(9878): android.os.DeadObjectException
09-13 18:49:02.578: E/Holla(9878):     at android.os.BinderProxy.transactNative(Native Method)
09-13 18:49:02.578: E/Holla(9878):     at android.os.BinderProxy.transact(Binder.java:496)
09-13 18:49:02.578: E/Holla(9878):     at com.sonymobile.holla.IHollaService$Stub$Proxy.resolveContact(IHollaService.java:239)
09-13 18:49:02.578: E/Holla(9878):     at com.sonymobile.holla.pluginlib2.HollaChannelProxy.setHollaService(HollaChannelProxy.java:256)
09-13 18:49:02.578: E/Holla(9878):     at com.sonymobile.holla.pluginlib2.HollaChannelProxyManager.setupChannelProxy(HollaChannelProxyManager.java:204)
09-13 18:49:02.578: E/Holla(9878):     at com.sonymobile.holla.rcid.RcidCallWidgetService.onStartCommand(RcidCallWidgetService.java:157)
09-13 18:49:02.578: E/Holla(9878):     at android.app.ActivityThread.handleServiceArgs(ActivityThread.java:2958)
09-13 18:49:02.578: E/Holla(9878):     at android.app.ActivityThread.access$2100(ActivityThread.java:156)
09-13 18:49:02.578: E/Holla(9878):     at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1449)
09-13 18:49:02.578: E/Holla(9878):     at android.os.Handler.dispatchMessage(Handler.java:102)
09-13 18:49:02.578: E/Holla(9878):     at android.os.Looper.loop(Looper.java:211)
09-13 18:49:02.578: E/Holla(9878):     at android.app.ActivityThread.main(ActivityThread.java:5373)
09-13 18:49:02.578: E/Holla(9878):     at java.lang.reflect.Method.invoke(Native Method)
09-13 18:49:02.578: E/Holla(9878):     at java.lang.reflect.Method.invoke(Method.java:372)
09-13 18:49:02.578: E/Holla(9878):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1020)
09-13 18:49:02.578: E/Holla(9878):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:815)
09-13 18:49:02.581: E/MDM(2625): [242] b.run: Couldn't connect to Google API client: ConnectionResult{statusCode=API_UNAVAILABLE, resolution=null}
Can this be fixed please in some upcoming update?
Note: I've tried factory-reset, it doesn't do any good - the failure is still reproducible.
2 REPLIES 2
Thommo
Genius
Have you tried a system repair and for bug reports then you need to forward this on to Xperia care as this is not something we are able to do as this is a user based forum - http://www.sonymobile.com/global-en/support/contact-us/
Haffiman
