[BUG]Proximity Sensor On Call
nuked
Hi
There is a issue with proximity sensor on neo_v
Normally If a call was accepted and phone too close to human face or skin after that Proximity sensor will disable touchscreen for any accidentally hang-ups, mutes, etc.
anyway first time works fine it will be disabled but after still on a call if phone going to keep away from face(skin) to anywhere than go back to face
touchscreen was not disabled
Proximity sensor failing to detect face or skin
Not good for people who speak on the phone too much
Sorry for poor english
Regards.
14 REPLIES 14
check if it works with Service Menu
http://talk.sonyericsson.com/message/113787#113787
nuked
@uliwooly-wooly
proximity sensor works all time on service menu test
but not working on call just first time works fine after that no luck
go to settings -> about phone -> check your android version and build number
also
how about repairing your phone with
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
this are methods on how to side load apps
1st Method
How to install it
You need to
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Installer
https://market.android.com/details?id=com.graphilos.apkinst&feature=search_result#?t=W251bGwsMSwxLDE...
open "Apk Manager" and voila select the apps that you wan't to install
nuked
Already I know I have lastest firmware on phone it's 4.0.2.A.0.62
I don't wanna repair phone software until verifying that someone else it's not a bug
fair enough
Sam
Legend
Legend
I have not been able to replicate that here so I would have to agree with Uliwooly and advise you run the update.
nuked
soon as possible I will try your suggestion
Thanks
