bug or a problem on NEO V
alam57
from past 2-3 days my SE NEO V get stuck and i have to remove the battery nd put it bck nd thn it starts again. yestarday wheni connected it to WIFI nd started to download a game it got stuck in adter sometimes and no matter any button i press it wont responsed  i had to remove the battery thn only it started to works this problems has happned 3-4 times and its terribly annoying, today i connected it to Computer nd thnn it got stuck wht to dooo????
6 REPLIES 6
FrontierGate
Your phone was frozen?  What did you do with it earlier?
alam57
it gets stuck sometimes when i start to download anything or sometimes when i connect it to computer.
FrontierGate
Did you just update firmware?  Did you install a new app?  Did you buy a new battery?
When did that begin to happen?
alam57
i had updated it to ICS 4.0.3  2months ago and about apps i download many apps every day and abot the battery i have brought the phone 3 months ago so the batery is fine, it started 3 days ago I think i have to repair the mobile software via Pc companion but i am afriad i will lose all the apps and games and other data so i wanted to know is their any other solution to this problem
FrontierGate
If you are not running anti-virus app or other task killer app in the background, try to repair it via PC Companion.
Otherwise this could be some issue with your SD card.
alam57
Thnks for helps.
