Every time when i make call i have to increase the volume.is it possible to save the volume on maximum level so i dont have to increase it for each time while making call
The volume is saved,it does not just go down by itself unless you press vol down button.
Actually thats the problem everytime i make a call the volume goes down by itself and i have to increase it manually.
Well,this is the only problem you have encountered?I would have recommended you to repair but just for this,I dont know...
check the volume buttons if its hardly pressed. the rubber under the buttons can stuck up that causes the volumes to automatically switch from high to lower volume.
Restart your phone by press and hold the volume up button and the power button at the same time until the phone vibrates if you haven't tried that yet.
