Brightness issue Z3 D6603 23.4.1.232
DanTse
My Sony Xperia Z3 D6603 has an uncommon brightness issue. After unlocking the phone from stand-by the brightness is noticeable lower than the one I set, without adaptive brightness on, and after a short period of time, usually under 30 sec, the brightness goes up to the level I set it, and stays like that as long as the display is on. This problem repeats randomly, but very often, maybe 80% of the cases. The difference in display brightness when this happens is probably 10% - 15% and is very annoying. I already did a factory reset and a fresh install via PC Companion with no results. The phone is 2 months old, no major software update until now so I can't tell if it's a software or hardware problem. Has anyone have the same issue? What do you think is a soft or hard problem? Any ideas of a fix is very wellcomed. Thanks!
Tags (1)
15 REPLIES 15
emk
Check low battery mode in settings >power management >low battery mode
Screen brightness
DanTse
Low battery mode is off. Stamina mode is off.
profile.country.RO.title
_alexdon_
@DanTse What firmware are you on?
alexdon
DanTse
5.1.1 23.4.A.1.232
_alexdon_
That's strange because it should have been fixed:
/t5/Xperia-Z3/Z3-bugs-on-Android-5-1-23-4-A-0-546/m-p/1042805#M24360
LE: Sorry, it seems you have a different issue.
alexdon
DanTse
My phone's problem is a little bit different, it's dimm when unlocked and gets brighter after a few seconds - a minute.
emk
I have the same problem but it's said that the solution is turning off the adaptive brightness which I wouldn't try it
DanTse
Turning off the adaptive brightness is not the solution. I don't use adaptive brightness. It happens even with adaptive brightness on, so...
DanTse
This is independent of the state of adaptive brightness.
