I unlocked the bootloader then after flashing custom kernel, entered into bootloop. in panic I pressed power button
+ up volume button, and phone turned off.
now cannot turn on phone, no led when plugged in charging, SUS cannot detect, PCC cannot detect, Flashtool cannot detect. What should I do?
I don't know if there's much you can do then. Perhaps some experienced flasher might have some tips for you. I will move this thread to proper sub forum.
I suggest you keep your phone to charging for hours and then run flashtool
Remember your phone should be off while connecting and moreover you need to press volume down key
Only hope is flashtool as PCC won't help ( Unlocked bootloader )
