Hi ,
Why is the bottom light when recieveing a sms or call doesn't keep on going if not seen the msg or unanswered the call. it wasnt like that , did something happen when upgrading ?! It only beeps once.
This seems to be a big issue on this board, I hope Sony are paying attention!!
Hope so because for my job when putting it silent is good to know when i have a missed call or msg
The notification bar never worked properly on my SP. It would never light up for texts. You can get around this by installing the "illumination bar notifcation" app from the play store. Select Xperia U in the settings to make sure all the different colors work. We shouldn't have to use a 3rd party app for this but until Sony fix this with a firmware upgrade it will have to do. If you're using stamina mode you'll have to add this app as an exception and it will work perfectly.
