Bottom buttons does not work
pillertrillare
Suddenly, the buttons on bottom of screen doesn't work. Back, Home and Active apps.
I've downloaded the latest software but that didn't help at all. The strange thing is that it works sometime, maybe every 20time I unlock the screen.
I think the problem started when some apps were updated. How can I restore the settings to the latest point of a working phone?
7 REPLIES 7
Thommo
Genius
Try Settings then Apps then tap the 3 dots then Reset app preferences - Reboot and test
pillertrillare
No, sorry, it didn't work. What do you mean with "reboot", can I do anything other than turn the phone off and then on again?
profile.country.RO.title
_alexdon_
pillertrillare
Ok, I turned the phone into safe mode, but the problem remains. Could it really be a hardware issue?
Phy
Legend
Legend
That seems to be a hardware issue, contact Sony Xperia Support
_alexdon_
Before you send the device into service,you may want to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Don't forget to backup
