Hi, mi name is Jorge from Chile. I have a problem with Xperia L bluetooth.
My xperia L bluetooth ussually disconnects in my car. Every 1 or 2 minutes off of my car handsfree, also disconnected music but less frequently.
Please your help in solution of this issue.
Thanks.
Jorge
This is happening to me as well. It is happening only after latest update 4.2.2. Before it was working fine.
First of all, remove the pairing from the phone under settings > Bluetooth > settings icon to the right of the paired unit > unpair. Restart the phone and pair the devices again. Also reset the car Bluetooth unit if that is possible.
I resetted the phone. So i had to pair again.
I even reset the car Bluetooth and paired again.
FYI, pairing is not the problem. It is pairing perfectly fine. After pairing, every minute for a second it will disconnect and connect again automatically.
Hi Alexander,
Pairing is not the problem. After pairing, the problem continued. I'll try to restore the phone.
I confirm if it solves.
Regards,
Jorge
Hi Alexander,
Reset the phone and the error was resolved.
Regards,
Jorge
Just wanted to fill in that I experienced exactly the same problem, but after a 'repair' in PC Companion, the Bluetooth issue seems to have disappeared
Hi support,
The issue persists. Now, the bluetooth disconect and is switched every 3 minutes.
I do not want to reset the phone again.
Help me pls.
Regards,
Jorge
I have the same problem after updating to 4.2.2. I already did the resets.
After pairing the car with the phone (which works), the car asks to access the phone list details and addressbook. This has to be confirmed. When I hit "confirm" the bluetooth service fails and the phone disconnects.
Actually I can NOT use the bluetooth connection in my car, which .... is not that good.
