Hi , i have bluetooth always On because its connect on my car radio , ..but when disconect i have battery drain from bluetooth (mah get very high) ...
if i dont connect to car bluetooth or restart phone wihout connect to bluetooth but is On no problem ... what i can do ?
So the problem is that if you keep the bluetooth on and synced to your car the battery will drain ?
no.. after i disconect from bluetooth device and go to battery i see the bluetooth use 10000 mah ..is that a bug ?
example... i connect to bluetooth device , after i disconect i see the bluetooth on battery stats 93%
got the same bug yesterday. after disconnecting bt car audio, bt consumption in battery stats goes to about 70% in a hour or two.
oh.. and it shows me bt working time "1044 hours"
yes thanks for confirmation ...the same problem !
Any Fix pls ?
BT stats (yes 1740 days. 1 hour. 51 minutes. 176 mAh)
BT was enabled for about 30-40 minutes. Just paired. No music, no calls.
I thought BT is low energy technology.. now I am just like John Snow. I don't know nothing.
please fix ...i need bluetooth On all day ...
Hard to say what's draining the battery, do you experience the same in >>> safe mode as suggested?
here ...
