bluetooth drops connection
davgray66
New
I have a Creative bluetooth headset and my Z1 loses connection if not used for a few minutes.  Not very helpful if being used for receiving calls in the car. I believe that the Z1 previously had a similar issue but a software update to 14.2.A.1.136 was supposed to fix this.  Doesn't appear to have worked for me.  Anyone else with a similar problem or prefereably a solution.
Alexander1
Have you tried to unpair the devices and then pair them again? If that doesn't help you can try to reset your headset and make a new pairing to see if you get a better experience.
If not, I would suggest that you try with another Bluetooth device to see if the phone behaves differently.
Also make sure that you have the latest available update for your phone:
