My Sola does not last beyond 13-14 hours.I do not use 3g or wifi, internet is used very rarely, power saver is always on. I just downloaded the new firmware through PC companion. Can someone help?
Go to settings/ About Phone/ Battery Usage and check there for power hungry apps.
I suggest you shut down the screen backlight, it can save up a decent amount of power.
1) Firmware ver. 6.0.B.3.184
2) No Task Killer nor Power Saver apps used.
3) Brightness approx. 35% with Auto Brightness
4) Reboot and put to Flight mode every night before going to bed.
52m 17s total voice call
It could be a faulty battery or signal problems ( i think phones consume more power at low signal since they try hard to connect or something, im not an android expert so dont take my word 100%) , my sola is now at 80% battery 15h after charging and thats with 30min gaming(FF III) 10min calls , 3g, and wifi on for the whole 15h ( no browsing just those FB notifications)
Still having battery issues. there, it's ok for a while, then the battery sudenly gets drained. Android OS is reported as being the battery eater, not much of an help.
After 4 days you have at least 30% battery. It looks very good . I get 4 days total with network connection online all the time. I still find it to be good. I'm still using .154
Have you tried charging the battery to 100% and leaving it to be charged until the little lightning symbol on the battery disappears?
Really, does this symbol disappear!!!!!!!!!!!!!!!
Yes.
My sola battery lasts only 1 day with moderate usage 😞
I usually disconnect charge when it shows 100%. didnt observe on the light indicator. will to today.
My battery comes to 100% if i charge for an hour.
