Battery Usage Graph in Lollipop
Makarand1881
The Battery usage graph is way inaccurate. One Day is represented by couple of lines as compared to showing the full chart The start date is 20th March.
6 REPLIES 6
Thommo
Genius
It shows the use since last full charge and by looking at yours it shows that it has not been used and also looks like Stamina mode is on hence the usage of wifi etc not been present
Makarand1881
The phone is used and on for more then 24 hours. it should then show a graph at the top with battery drain also the time shown at the bottom should be increasing and not decreasing. there is definately somthing weird about it. the battery usage in my nexus 5 is not like this
dany68
Eleven days in my z2 bat.... With normal use....
Domvs
Hi guys,
Where can you see the battery usage time with Lollipop? I don't find it... Thanks in advance!
mludwig
I just upgraded to 5.1.1 and my battery usage graph looks the same. For some reason it starts ~two weeks in the past. I already did a factory reset/repair and it's the same.
mludwig
After charging the phone to 100%, the battery chart got reset and now it's properly showing the discharge history.
