Battery Status Indicator.
shaileshshetty
My Xperia U battery shows 8% even though I keep charging for 1 hour. But if I shutdown and restart, it shows 77% charged lol... ๐Ÿ˜ž
What can I do? Should I replace the phone? Because battery backup is only 3 to 6 hours.
Very bad..
6 REPLIES 6
do you have a taskiller or antivirus or battery app?
repair your phone with either SUS or PCC
http://talk.sonymobile.com/message/244522#244522
Update Service (SUS)
shaileshshetty
I have Avast Antivirus. Shouldn't I?
I don't have Battery App. I have installed one app called Device Info, which ends the process, and releases the ram memory. Should I uninstall?
My Phone keeps only 30MB free ram... and runs slow... it takes more than 90% CPU Memory.
Camera loading takes more than 3 seconds. capturing also takes more than 3 seconds....
Kindly help me...
Rado77
It's a serious bug, we discussed it in other topic. It's showing correctly only when phone is charging via USB PC. Using wall charger cause this problem - yo dont see battery icon movement and % is still the same. After reboot you see real % of charging. But it's not big problem I think because this phone is fully charged from wall charger after 2 hours or something like that. So let it there half our later and U are sure that is on 100% Winking_Face  Or charge via PC if you have time.....during night/work...
shaileshshetty
Exactly correct @Rado77. But In this case, if cahrge is below 15%(AS PER INDICATOR) it keeps on pop-up error if I try to make call.
adyt5
d same thing is with me  dnt wry after u charge ur xu for an hour or so and pull out the plug and wait for few minutes and watch.....it will start rising up.....gradualyy
