Battery calculate according to the recent use of phone, so while most apps are not on use, and phone is not active much, tho there will be a variation every time you check the battery stats...
Its quiet Normal ...
I'm not sure who is confused? what is the relation between battery load and percentage of charge left out?
Well, according to me % of charge which is indicated have no relation with number of application in use.
Regards,
Try Third Party App
https://play.google.com/store/apps/details?id=com.darshancomputing.BatteryIndicator&hl=en
Restart
Restart your phone to turn off all running applications and to free up memory. Press and hold down both the volume up key and the power key for 10 seconds. After your device vibrates three times, release the keys. The device turns off automatically. After the device is turned off, restart your phone.
Update Service
Update your phone for optimum performance and get the latest enhancements. Regardless of whether you have the latest software, it’s a good routine to run the Update Service to improve software stability. Also, if you experience problems with your phone this may be solved by a software update.
I face problem with the update, connection did't done when I hold the vol key while connectiing as instructed.
I have the same problems. Sometimes when i reboot my phone when it is charging, lets say it is at 40% and i reboot while it is charging sometimes it goes up to 70%. Than when it is 100% and i use it it shuts down at 30% and then when i charge it again it says 1%. Very annoying..
I use .145 version and .141 both same problem.
I also have that problem ^^ Sometimes when i reboot my phone without charging it, it sometimes also gives me a wrong reading. Like i reboot at 12% and then it is 35% or something. But it does shutdown at 23% (35-12). Hope to get an answer. This problem excist a long time
