battery replacement
vbozios
battery replacement
the enclosed battery has poor capacity.  i want to have a bigger MAh battery.  is this possible?? which is the model of the battery? where to find a better battery?
3 REPLIES 3
xallobj
The battery is not designed to be replaced by the customer. It would definatly void your warranty to replace it.
vbozios
so there is no solution of changing battery...what a pity !!!...
any ideas to increase battery life???
you can't get a higher mah battery, even if you buy a new original battery for your handset, you'll get the same mah of battery, and using original accessories of sony won't void your warranty
Don't forget to mark Correct Answers & Helpful Answers
