battery replacement
battery replacement
can i replace my battery or upgrade it , because im using my xperia p and the battery seems to run out fast, xperia p have a lot of good features and im happy with it, browsing, playing, youtube, camera, user interface, but battery is the only downside of this product.
for playing games - 4hrs or less, the battery runs out
browsing - 6hrs, the battery runs out
music - 18 hrs, the battery runs out
2 REPLIES 2
charge your phone 100% -> press and hold volume up and power -> use it as you normally would, do NOT charge it at all
once you get to 10%
settings -> about phone -> battery use
take screenshots of the battery graph and the list of apps and services
tap on each item on the list and take screenshots or write down everything and post it here
remember that the more you sync the faster your battery will drain, also if you are using taskillers, battery apps or antivirus they will create a lot of issues and drain your battery faster
you might want to read this
http://www.engadget.com/2012/06/18/android-wakelock-api-bugs/
Android apps that use power control APIs are often 'battery killers,' oh the irony
http://www.tgdaily.com/mobility-features/64061-api-glitch-may-explain-fast-draining-phone-batteries
http://www.purdue.edu/newsroom/research/2012/120613HuSmart
