Battery Problem with my xperia P
kayed
hello guys,
when i plug in my Xperia P phone to the charge it takes 30 min to get it full,
when i see the batery use, i see a trigger in the trajictory of the batery use, which i see it not something good because when restart the phone it drops quickly in 5 minutes to the 50%???
is there any solution to this thing
4 REPLIES 4
nabendu
keep the charger plugged in for atleast 2 to 2 and half hrs inspie it showing 100% then press volume up and power button for 10 secs and on three vibrations the phone will get swiched off !! then restart the phone and continue charging !! this should solve it !! or else use repair option in pc companion and try ur luck if above method does nt work
itskiran2000
used to face the same on .162, update your FW, i dont think it takes 2 to 2 and half hours to fully recharge, since it's a powe charger it takes not more than 1 and half hour to fully charge Slightly_smiling_Face
kayed
thank you for your reply, but does this actually do (power button and the volume up) thing??
ryan515
if your phone shows 100% while charging make sure that the Battery bar on the upper right of your screen doesn't have the thunderbolt sign in it.
