@JoelRaj wrote:
Well my Z3 says estimated battery life 1 day With a 100% charge... And well Sony promises 2 and a half day.... So I am just concerned about it now. Is it usual??? Well, battery does depend on usage... But still with an 100% charge... Shouldn't my mobile estimate what Sony promises?
Can you post a screenshot of the Battery Usage & if you can look & see what Apps are consuming power etc
Mine says 23 hours. Or 3 days 19hrs on standby. My battery is on 56%. No stamina mode active
active.
The widget is an estimate and is based on your usage over around 2 or 3 days from the same amount of days prior - So if in the present you are a light user then the widget won't say this as it's giving a time from days before however in say 2 days time from now what you did in the now will be seen as your estimated time now,
Sounds confusing
Sounds confusing
If you want to reset stamina mode or the counter, first make sure stamina is disabled, go to settings-apps-all-eco mode controller,force stop and clear data.Restart and charge the device to 100%.
