Over the past few days I have had an issue with the battery indicator of my Xperia go. Sometimes when I plug it in, the battery life percentage does not go up at all, even after several hours. But then if I reset the phone the percentage shows correctly (100% or whatever it's at). Has this happened to anyone else and is there a way to fix it?
Maybe, you need to callibrate battery guage.
Have had exactly the same issue myself. Suspect it's a bug as otherwise my guage acts properly.
it happen to me and i think there is nothing to do
Which build number are you guys running on?
6.1.1.B.1.10
6.1.1.B.1.10
Hi there,
Same PB with the same build : 6.1.1.B.1.10
This PB occured when my phone goes down because of too low battery.
When i try to charge it the battery is always at 0%.
After several hours i reset it with the keys up + power and then the battery is close to be fullfiled.
I have already reinstall the soft with sus.
And i have also the issue with learning client 2.1 which is cusume a lot of battery
