Battery duration
snk123
Battery duration
I bought my Xperia E3, on sept 14.for the past 2 week,my phone does not hav a long battery duration.when i connect to mobile data(GSM),within 3to 4 hrs phone drops from 100% to 35% ....pls give a solution. i  use whatsapp only in my phone. Model :D2202 thanks in advance.
9 REPLIES 9
profile.country.RO.title
_alexdon_
Do you use WCDMA (3G) or GSM (2G) in network modes?
alexdon
Settings > about phone > status > signal strength, what do you see there?
Jake-SonyXperia
Hi snk123,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You may also want to check the Power Management section, this will shed some light on the expenditure of the battery.
Menu > Settings > Power Management > Battery usage
snk123
i use 2G network always....
snk123
Signal Strength-79dBm 20asu
Jake-SonyXperia
What are you getting from the Battery Usage info? is this showing what service is running the battery down?
Prachurjya
Go to Settings > apps > all > eco mode controller > clear cache > force stop then switch off your device. Fully charge the mobile. Its better to switch off the device before charging.
snk123
still problem continues.....any1 ps help.....and after updating to 4.4.4,wifi turns On very slowly.....and ever 3 minutes battery drain by 1%.....any1 pls help....thanks in advance.
Jake-SonyXperia
Why don't you try a backup of content and then attempt a software repair on the device, this could simply be a bad installation.
Backup instructions
Software repair instructions:
1. Before you start you have to download the PC Companion software from PC Companion
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
