Battery drains faster with Lollipop
michaelkvr
my phone battery drains extremely quickly. for example, today i had 80% and after about 30 mins of no use whatsoever, is gone down to 60%. didnt even check the time on the device. noticing this for a few weeks. when large apps are opened the charge drops from 80% to about 20% in less than 5mins and shuts down. on recharge becomes 100% in 10mins and drops down again. almost as if the battery has lost the capacity.
12 REPLIES 12
@michaelkvr
This has been asked way too many times, reinstall the latest update with PCC and report back in 2 days
PC Companion (PCC)
Bridge (for Mac)
michaelkvr
tried it. pcc says phone is updated.
@michaelkvr
But of course, it should give the option to repair the phone by reinstalling the latest update.
John-BR
Hi Michaelkvr
Welcome to the Community.
Here's how to run the repair on PC Companion:
  2. Phone Software Update.
  3. Start.
  4. Repair Phone
  5. Continue
  6. Accept data removal
  7. Next
  8. Wait for prepare
  9. Select Phone
And Bridge for Mac:
  2. On the Main Window select "Xperia > Repair Xperia Device".
  3. Ensure the phone is charged and select "Ok" in the following window.
  5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
GrexZ
Hi, I have problems with my C6903, I did all, installed update, reinstall software and nothing happend... my phone says 100% of battery and its drains faster to 80% so when the battery has 80% or 76% the phone turn off with the message ''Turning off 0% battery'' after that sometimes the phone gets start to turning off and turning on many times. I proceed to connect to the charger and appear in the screen 56% but if I turn on, appear with 68%. Please, help. What can I Do?
@GrexZ
Contact your Local support ASAP
GrexZ
Hi @uliwooly Thank you for your fast reply. You are an expert in the area o if you send mi to the local support then maybe my phone has not solutions, You dont tell me any idea if the problem is software or hardware.... or battery. But, Thank you again.
@GrexZ
If PCC doesn't solve the problem then it's most likely a hardware issue, do you experience the same while on safe mode
GrexZ
@uliwooly
Thank you... I understand, but I dont know how to active the safe mode. Can you tell me how?? I have a C6903.
