battery drains during stand by
waruna93
battery drains during stand by   . it had a great battery first . i used it more than 2 days .. but now it cant even use 1 day . battery drains during standby  , please help
26 REPLIES 26
sp_ers
Make sure no new applications installed before problem occurred.
Try to switch off Background data.
Battery drain usually caused by bugy application they prevented phone from sleep.
How about battery Stat, any application used power unusual.
The last important ones, signal strength. Fake or I call it echo signal it drained battery, it looks like good signal but you are troubled connect to Internet. When it happened try to switch to 2g.
waruna93
i reset my phone and deleat all data 2 times and i repaired my phone using pc companion but nothing works  . in battery usage cell standby shows 29%
Rajesh999
please activate stamina mode ... previcly i was also same problem. after that i was activate stamina mode it is work for me...
Tags (1)
waruna93
i activated stamina mode . nothing works still battery is draining .
Andy9879
Remove weather widget and see if it fixes ur problem. It solved the battery drain during standby for me.
daverawle
Install Wakelock Detector to see what is preventing the phone from sleeping.
Dave
ShinOrochiX
I have the same issue, lost 20% in 8 hours of standby, with stamina enabled.
Although for me the android system used nearly 90%, which definitely shouldn't be occurring.
Any fixes guys?
ShinOrochiX
Just to add I'm on the latest 4.3 firmware (.205), never had these issues on 4.1.2.
waruna93
how to remove whether widget
