Battery Draining Too Fast
Viveksonthalia
Recently I have observing that the battery is draining too fast even when the phone is not in use and the PHONE IS getting HOT VERY HOT...
what should be dont...
17 REPLIES 17
coolasrevi
Phone , firmware and snapshot of battery usage details please?
Viveksonthalia
XPERIA Z
Screenshot_2013-06-26-13-14-49[1].pngScreenshot_2013-06-26-13-14-57[1].pngScreenshot_2013-06-26-13-15-19[1].png
coolasrevi
Hot because of 3g.. turn brightness to auto low. use only stamina mode. low battery mode is not necessary. with data always on it gives decent battery life. and update to new firmware.. battery back up increased noticiably and i don even use stamina mode in it.
Viveksonthalia
which new firmeware  should update with
coolasrevi
4.2.2 is out check in Pc companion.. if you dont get notification, you wil get in a few day
Viveksonthalia
thanks
JakeSully
reason why your battery is draining fast is due to mediaserver is on, and lower screen brightness like coolasrevi said Slightly_smiling_Face
Viveksonthalia
so how do I stop media server or modify it to work in a lower value
JakeSully
actually mybad it was your wifi hotspot that was on Slightly_smiling_Face so if your not ussing it then disable it on your phone Slightly_smiling_Face
Wifi HotSpot usually drains the battery faster since it uses alot of battery usage sorta Slightly_smiling_Face so never leave it on when your not using it.
