Hey Guyz, i mhaving problem with my xperia z1 battery.....it drains very fast....last night i did a format to my phone nd on 100 % battery remaining time was 2 days nd 8 hours remaining......but after installing some apps now on 100% battery remaining time is 18 hours.....
what is the problem......i checked in the battery usage...here is the picture
Battery is 100% stamina mode is on....still just 19 hours.....u can have a look on battery usage too
Okay Guyz Thaxxxxxxxx 4 The reply....i will check it out...but after formatting.....it showed remaining time 2 days nd something....nd suddenly now 19 hours datz why i m worried about
I see that you have poor signal.. If you have enable WCDMA or LTE mode you can switch to GSM only because the signal is better and there is a limited coverage for 3G, 4G, H+ networks (depending on your area) and your phone use more power to search that kind of networks, If you don't use mobile data often you can switch from WCDMA to GSM only. (A little compromise between internet speed and batery life)
I disable WIFI, Bluetooth, Location services, set Keep WIFI on during sleep to "never" , Scanning always available off, stamina always on. I also try to keep off background services like auto sync. I don't like wasting battery power with automatic synchronisations because i consider that I'm not so lazy to manual sync accounts when i need it.
This estimates my battery to almost 2 days and 10 in standby mode. It also depends of usage history you have to future battery time predictions.
PS: Also avoid draining the battery to 0 because it affects the overall life of the cells. it is optimal to charge the battery in the interval of 10 - 20 %
