Please help... I can't seems to charge my z1, the battery keep draining even when i use the wall plug to charge it. Now i think it is totally out. Tried to charge it but red blinking light keep blinking. Tried to press "power+up button" no effect. PC companion can't detect my phone. What shld i do next?? Hope someone can help me
You need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
Hi, are you using the original USB Cable & Charger.....may be worth your while trying a different USB Cable then a different wall charger if you have them, that way it rules out the actual chargers/cables as the possible fault........if no luck with that then follow Thommos advice......good luck :smileysmileywink:
