battery drain like in first release for xperia 2011
zakk87
Hi, have Xperia Sola and Neo, and I remember that in software version 4.1.A.0.562 for Neo V was a battery drain after a few days due to kernel wakelocks. Solution was reboot after charging and situation was come down. In software version 4.1.B.0.431 and 4.1.B.0.587 this error doesn't exist.
In Sola 6.1.1.B.1.10 I noticed the same bug after few charging. Phone draining a battery until I reboot It.
I'm using a clean software with tapatalk only.
thanks,
Adrian
3 REPLIES 3
tbb1mb
charge ur phone till 100%, repaire via SUS, then charge ur phone back up to 100%, after that use till the battery is empty, then charge it back up to 100%, to calibrate your battery
Kurukuru
I see a random wakelock (reported as Android OS in battery use) issue with my sola on Gingerbread (6.0.B.3.184, which is the latest release for my SI number).  Sometimes, after charging, Android OS is responsible for over 50% of the total battery drain and the battery lasts about 24 hours.  Other times, Android OS is way, way lower and the battery lasts about 48 hours with virtually the same use pattern.
I am really, really unimpressed with the quality of Sony's software and will never buy another Sony phone.
zakk87
I think they working on it. But for sure i reportet it as a bug.
