Hi, can you give us more details....how long it lasts from 100% etc
Maybe post a screenshot from settings-power management.
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Hy i have a problem with the battery,it,draining very fast i can use my about 3or 4 hours and i need to charge it.Evryone has a solution for this problem ?
Hi Rockman, that's pretty alarming. Could you post a screenshot after you click on the [screen 22%] usage? Or just tell the time how much screen you used?
Was this xperia z3 or an older device? And whats you routine usage?
And Rockman, try switching to Safe Mode to observe similar behaviour, then report.
