battery discharge
Arvin
battery discharge
Hi there,
Xperia M is my second smart phone, previously I was using Nokia Lumia 520 which has a better battery life.
Coming to my xperia m the battery discharges very fast, even though im not using internet, if i uses the phone normally battery drains almost in a rate of 10% in 10 or 15 minutes. that is if battery is at 100% it will become 90 -89 very sonn in minutes.
How many of you are facing the same thing. Is this an issue with my battery, Should I replace the battery.
5 REPLIES 5
Fahim715
What app that you install in your phone?
Don't always use app like Facebook, Whatsapp and Antivirus
It will always running in background and make you phone slower and eat more battery..
gwhispererz
For your info, http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancements-features/m-p/347874#U347874
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
Arvin
If i have to turn off all these
then why should i need a smart phone.
A normal phone is enough
Arvin
ya..thanks..
But I am feeling this as little strange.
For the same specs and battery howother android phones give more battery life.?
like samsung galaxy s duos
gwhispererz
That is just a guide, you don't have to turn off all those all the time.
Alternatively you may want to software repair phone just to confirm that it is not a software issue. However, be aware that this process will erase phone data completely, backup if necessary.
Take note that battery performance will improve after several charge cycles.
