Hi, I was wondering if anyone can help with this, My xperia s updated to Jellybean a few days ago all is fine but when i charge the phone and then remove it from the charger the green battery light stays on and therfor drains the battery quickly the only way i can get the light to turn off is to turn off the phone and turn back on then the light is off, i have gone through the settings and i cant find anyway to stop this, does anyone else have the same issue and if so how can i rectify this.
Any help would be appreciated.
southcoastdj
got the same problem but not all the time - same here turning phone off and back on seems to be the only way to clear it at the moment
I have come across a solution, if you dont charge to 100% say 98% then the light dont stay on, give it a try
I suggest that you try to press and hold the power button and the volume up button at the same time until the phone vibrates.
If you still experience problem I suggest that you try to repair the phones software using PC Companion:
That doesnt work. i tried it 2-3 times.. This issue is very intermittent and happens once in a while. Sony has to develop a fix for it.. 1000's of people are facing the same issue
